I am so lucky lately. f22a6 auto
I had this pop up once before but now something has to be done, Just tonight I was trying to make it back home from work (normaly a 20 min drive) but my car at a stop light would bog down run at 200rpm and at a few lights stall when it would stay running and the light would turn green it would bog really bad with gas then it would jump jump then either die or I would have to pop the pedal to make it go but it would go up to 2k and bog if I wanted any more power.
It thew a C.e.l light and the code came up as a 3 - map sensor
I then went and pulled the backup fuse and waited the 15 mins then the car would run and drive fine.
I'm wondering if I should grab a map sensor at the yard and see if this goes again then replace if it does.
I did try to get some info from
http://www.cb7tuner.com/vbb/showthre...ght=map+sensor
