for some reason when i really rev up my car and then shut it off and look at the groung behind the muffler it will have oil sprayed on it.could it be condensation mixing with the smoke??it happens really bad when the engine is cold.whewn its cold just staring it up and not reving it makes the spray type stuff.any ideas.also when i really get on it hard black smoke comes out of my exhaust.bad????or ok it does burn a lil oil.please help
smokey pipe-carbon in exaust?
its carbon...its ok to have, sometiems there is alot of that crap in the systemWhat makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
Andrew
Your motor is old, so unless you feel like doing a rebuild, yeah, it's going to burn a little oil.
Have you checked the consistency of whatever black stuff is coming out the tailpipe? Yeah, it could be carbon, but I'd like a more accurate picture of what's happening before we rule other things out.
i would run some seafoam thru the throttle body and PCV valve, that should loosen up some of that carbon, it will stink like shit for a few miles, but it cleans everything out, cleans out the odors from catalytic converter too, you can run it thru your gas tank to clean your injectors, i personally didnt do that, but it is an option.. you might have some sort of leak.. oil just spirts out from just sitting at idle tho?.. listen get some seafoam put it thru throttle, be very careful not to drown the engine or you will hydrolock that bitch and then need a new engine, so... carefully use that stuff it will get rid of that carbon..
Originally posted by fizzbob7
if your car burned a quart or even 1.5 between oil changes, it would be ok......most hondas don't burn oil (most imports are the same way) because of tighter tolerances than what domestic makers have used for years......that way, when they have a lot of wear on them, they still might be as tight as a stock mustang's clearances.......and go new car shopping for fun.....ask them about it......most of the time, they'll tell you that even though it's brand new, it's supposed to burn x amount of oil.....the 4.6 mustangs were supposed to burn 1.3 quarts per 3000 miles or 2500 miles of hard driving.....people complained, but ford guaranteed them it was ok.......and in reality, it is
well the problem i'm having is not really oil ,i have a 5 inch exhaust and you know when u look in your pipe and its black,well its like going to the car wash and getting some water in there and then starting it right up and reving it,it does not do it when its hot,when its hot it just smokes a lil(black smoke not blue)
well i dont use additives any more i did it just to find out that my engine on that car was perfrect and had no carbon deposits at all and wasted my time, but the car is gone so i have no idea of what adverse affects it had on it, nor do i care anymore but i wont be using it on my F22b motor, im leavin it alone.
soemtimes excessive carbon build up is just the muffler itself....usually people dont get it but my uncle jsut started spirtying out black crap...he changed the muffler and its gone...
if u were to clean otu the intake system it would be nice, yet running some fuel injector to get the carbon off of the cylinders is better...
iono how well it will clean out the system...but it will clean ur vitals out...
my car doesnt burn oil =)What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
