My Abs system is not working that I know of, I had a light on in the Instrument cluster which i took out years ago and Im planning on doing a wire tuck so besides removing whats under the hood what else would I run into?
Abs Removal Help
The brake lines are routed through it but you can still take it out. You will need to replace all front lines in under the hood with the lines from a non-ABS Accord.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
Where the proportioning valve sits in the bay in a non-ABS Accord there is a splitter. The lines that direct flow to the rear from that splitter are the same on an ABS car and a non-ABS car.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
