Hey guys at Cb7tuner. I wanna ask a quick question, though I regret having to do so its just I need to know what's up with this. I just bought a JDM F23 long block (ordered it) and am gonna do the F22 head swap on it. My question is, you guessed it, about the timing side engine bracket. I know that just about everything from the F22 engine errrr I mean shortblock can be used on the F23 short block perfectly. Everything except the timing bracket. 1 of the bolts don't line up... I just can't stand the thought of having only 2 of the bolts for such an important engine component. Here's my solution. I use the original F23 bracket by drilling a hole in my ESP timing bracket so that it lines up.
Here's what I mean. This is my bracket (actual pic). I say cut a hole right where the dot is. Would it work is my question.
I've already seen people from the 6th gen site do something similar for H22 swaps. That is they modified the H22 bracket to work with their F23 mount.
Normal F23 bracket withe F23 engine:
And here is the modified H22 bracket to work just in the same way.
Cool huh? Why can't I make do something similar, that is my question.
