Sup CB7 chumps, yeah like the title says. I normally put 4.6 between 4.75 qts of oil for my car (swapped) but today after doing my oil change, I added a full 5 quts (the big Mobil 1 container) and it was only up to the half way line between the two holes on the dipstick. So I pour in another .7 qts and that made it perfectly right at the top dot on the DS. I can see I will need a new oil pan gasket and pan soon, but there was never any oil drip spots anywhere i park. Its not dripping at all, but 5.7, thats a lot of oil. Maybe because i used a different filter this time, maybe? I noramlly use Honda OEM, but today i switch to the Mobil 1 oil filter. Anyways, what do your h22 usual takes?
5.7 quarts of oil in my H22A?
Originally posted by ERACERand it was only up to the half way line between the two holes on the dipstick. So I pour in another .7 qts and that made it perfectly right at the top dot on the DS.-'93 Accord EX 5-speed F22A6
-DIY mesh grill, DIY stealth intake
Yup. I did as I always have, pour 4 qts in then start, run for 1 min, then took off, wait 10 mins (I just like to give it more time for the oil to settle in the pan) then check level. 1st 4 qts, level under lower dot. there is no leaking from my oil filter, old gasket was still on old filter. well I check it this morning before I left home and it was fine. No leakage. But still 5.7 in in there, somewhere?
thanks for all of your replies.I can accept failure. Everyone fails at something at some point, but I can't accept not trying". MJ23
Time and Money BOTH is why I do what I do
