well guys long enough and finally i got my motor in and all hooked up. now the only problem is it seems to be missing. it idles like shyt almost to point of stalling. ive ordered new honda spark wires, cap and rotor. hopefully thatll smooth the idle out. i that doesnt work ill have to adjust or check cam timing. anyone have any thoughts. oh and its a f22b1 in a 93 accord. i have poa ecu and yes switched the a6 and a11 wires as well as added 2 wires for vtec. the only other thing to mention is that the poa ecu i have is mugen chipped. could this affect idle or is that just above 2500 rpm. ive also ordered another poa ecu stock from junk yard just in case. just hopefully isnt not a bad cylinder. thanks for your help again
ok motor in
