So as not to confuse everybody in Joey's thread.
Recently I have noticed. When I turn the key. Sometimes it is hard to turn like it doesn't want to, then I wiggle the key and it turn. (this I believe is the tumbler and I think a cleaning should fix this. Hopefully)
The second problem is the clicks you get when you turn the key are gone. Its like you turn it but don't feel the click for acc or the ignition click. Then when you turn the key to start. It gets stuck on start and I have to manually turn the key back. Which usually results in me turning the car off.
Is this the lock cylinder or the ignition switch. First thought was the lock cylinder but after reading some I'm not sure.
Car runs fine doesn't shut off or anything like that.
thanks
steve
thanks
steve
