Hey all, I have a question about an engine I want to get as a spare in case my engine breaks down. I know of where I can get a complete H22a engine but it may need rebuilding the owner said because the "oil pump may have failed". He said that because the oil pump was improperly installed (how can you improperly install an oil pump is my question). He wants 300 for it. My question is if this engine really does need rebuilding or if this guy is just being over cautious. He said he would do it just for good measure. He said the history of the motor is unknown, he doesn't even know how many miles are on it.
My question is what are obvious signs this engine is healthy or not without having it in the car, a leak down test, or physical examination of the cylinder head? If in the case the engine is damaged and is leaking compression (from damaged rings or pistons), would overboring the engine 0.25 mm over be a good idea even with its FRM bores?
I think I shall go and see the condition of the engine and bring with me a compressor and my leak down test kit. Take off the valve cover and see the damage if there is any. I wonder what it is I should look for.
