Hello. I believe I have found a longstanding oil leak on my rebuilt engine. It leaks about 1 quart every 200 miles and has leaked after numerous oil changes. I have pics I took while the car was running and on jackstands (best way to look for leaks, worked like magic).
This is right as the car warmed up, you can see it seeping out of the oil housing. This oil filter is new, the gasket is new and the mating surface appeared to be perfectly clean. I somehow doubt that it is not on there tight enough because this oil leak has been happening for over 5 oil changes. Maybe I do not tighten my filters tight enough? I will check to make sure. How tight should they be? I think it was like 1/2 a turn after you get it on there good.
After about 5 minutes of idling:
I suspected there was something loose on top such as the oil passage bolt. I will check to see if its loose. But I know its not the oil sender, that was dry when I looked at it.
