So M2S4 is in and there is a noise in neutral with clutch pedal up. I can't think of anything else but a bad bearing. What I want to know is what is that bearing called? Too many bearings to choose from and I do not know too much terminology of a transmission.
Transmission Bearings
Be unique, like every other person.
CB7 Sold________________________E34 Sold________________________E39 Current
Tags: None
*similar*not prelude trans---^
PowerTorque® - Manual Transmission Bearing Rebuild Kit
Part # BK387
Part Number: BK387
Line: PTQ
1 Year Limited Warranty
UPC: 771112151989
Detailed Description
Power Torque Transmission Rebuild Kits contain all bearings, seals and gaskets required to refurbish a Manual Transmission.
Kits available with and without Syncronizer Rings.
Small Parts Kit, when required by application include needle rollers, washers and shim
$592.99 Each Call for
availability
O'Reallys
You should have a test drive by a professional, pull the transmission and outsource that jobLast edited by illinois_erik; 09-27-2013, 05:01 PM.
Pedal down it is gone. I think part 20 is what is the problem. $500 too much, all I need is the one bearing, but the diagram is quite helpful, thanks.Be unique, like every other person.
Originally posted by XCRN View PostWhat I want to know is what is that bearing called?
Originally posted by reklipz View PostYeah, it's either #20, or I suppose looking at it, it could be #1. I have the same issue with my car right now; I've just been riding it out until I do a rebuild.Be unique, like every other person.
The throwout bearing was replaced, Honda OEM, and there is no noise when the pedal is pressed down, only when it is let off. When I press down the pedal the noise continues for as long as it takes for the friction disk to stop rotating.Be unique, like every other person.
Is there fluid leaking out the transmission anywhere? #1 & #20 would be my primary suspects.1993 SE Coupe MRT - 1992 LX Sedan MRT
93 Accord SE Bose Stereo MYTHS & FACTS - F22A* Power Plant Removal(UNDER CONSTRUCTION)
Did you yourself install everything including the throwout bearing or did someone else do the work? Was the new one never installed by accident? Those symptoms are spot on to a bad/noisy TOB. When it's unloaded w/ no pressure it'll make some noise and once the pedal goes down a hair, it'll be quiet. Also, what do you have for MTF in there?
I did the clutch job myself, and I made sure I used the Honda throw-out bearing. The one that came with the clutch is still in the package. I put in Honda MTF. I have been checking every morning for leaks and there are none. Remember this a junk yard engine and I guess the noise was there when it went to the yard.
It takes more than a hair to stop the noise, the clutch needs to be making zero contact with the disk to stop the noise.Be unique, like every other person.
