Alright so my accord is idling at 1500. Let me start by saying I've got a 90 ex f22a1 block with a6 head and intake manifold. I gutted the spacer piece it the butterflies so no butterflies. I also deleted the fitv. I've already tried to adjust it with the screw on the throttle body but it's at the lowest point. I can't figure it out as for the running rich I'm hoping it has something to do with the high idle. I have deleted the charcoal canister but other than that it's exactly the way it came from factory. Also I have a bit of a backfire not sure if it has anything to do with the other stuff I'm thinking I may just need a valve adjustment
idles high and really rich
Running rich and idle high could be an O2 sensor reading incorrect data, which also = an air leak. Seeing as you deleted the butterflies you should be looking into an air/vacuum leak with some soap and water spray or carp cleaner (<- be careful, do your homework here).
May help, best of luck.
