So I started taking everything out for transmission and clutch swap, got as far as the clutch line and it spilled some fluid. Since I now need to drive my car to get the axle nut off I start putting things back together and now the clutch pedal will just shoot to the ground because of the spring when pressed. I filled the master cylinder with some fluid to bleed it. The fluid in the reservoir is not even going down in level when I pump the pedal and bring it back. My guess is the hole in the line and the bolt are not matching up maybe.
Clutch Pedal No Return
Be unique, like every other person.
CB7 Sold________________________E34 Sold________________________E39 Current
Tags: None
Also to add to the information, when I press on the clutch fork into the rod I see the level of the fluid will raise and bubbles will sometimes come up. When I look below, not sure what to look for but I am looking at a rod connected to the pedal go in an out with the pedal so I am lost here.Be unique, like every other person.
That is what I am attempting to do, but still the level of the fluid does not change. I did try one method where I pump and leave the pedal depressed and then loosen the screw on the slave. It worked momentarily but it goes back to not pumping.Be unique, like every other person.
Got one of those vacuum guns and it worked, the clutch is hard as a rock, which I like. The only other cars that are stick that I drive are trucks, jeeps, etc so I will feel right at home. I will try to tune it a bit, any tips?Be unique, like every other person.
