I swapped the p2t4 this weekend. Car seems to run rich some then lean some.
After the car is warm. When I try to get VTEC to engage it won't. Light came on for two days. Yesterday I took the vtec solenoid off expecting the screen to be dirty. It was clean.
So yesterday. I disabled my vtec oil pressure switch. No cel but still no vtec.
This only started happening after the swap. Before the swap All seemed good.
Car, 91 accord LX JDM 96 obd 2 converted to OBD1, P28 hondata s300, LC-1 wideband. Vtec worked fine before the tranny swap.
I thought the s300 stored the codes, but there are no fault codes on the ecu, or when I jump it.
Tomorrow I will use my laptop on the drive in and enable the vtec oil pressure switch. So I can have the laptop connected when the code hits.
Yes the VSS is working, oil level is good, OIl is castrol in the gold jug 10-30 K&n oil filter maybe 1500 on this oil change. oil pan is not dented.
Any ideas or something I might have missed.
steve
steve
