hey guy I need some advice when i did my motor swap ( which was last summer) i put brand new Innovative Mounts. I just started to drive the car everyday and it feels like a have a bad rear mount. so i took a look at it and it looks fine all the bolts are nice and tight. Its driving me crazy, i think its 1 of 2 things. 1. i got a bad motor mount from the beging or 2. when i was buying the motor mount they had three different types of mounts for cb's 3 bolt short style ( which i herd are for Lx MT) and there a 4 bolt tall style ( which are for EX MT) i have a MT ex model so i ordered the 4 bolt style. Is what I herd correct Im starting to think i have the wrong rear mount. any advice will help
bad motor mount maybe?
Did you check for what would look like cracks in the rubber . If it is separating then it will allow for extra movement . As long as the bolts are in all the way and tight i don't think there is a problem with them. Also it could be the front. If the front or back go bad it will allow for same direction of movement .this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
Originally posted by Accord problems View PostDid you check for what would look like cracks in the rubber . If it is separating then it will allow for extra movement . As long as the bolts are in all the way and tight i don't think there is a problem with them. Also it could be the front. If the front or back go bad it will allow for same direction of movement .
Go to kragen not autozone . There stuff is crap.this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
Originally posted by Accord problems View PostGo to kragen not autozone . There stuff is crap.
Originally posted by Accord problems View PostGo to kragen not autozone . There stuff is crap.1993 SE Coupe MRT - 1992 LX Sedan MRT
93 Accord SE Bose Stereo MYTHS & FACTS - F22A* Power Plant Removal(UNDER CONSTRUCTION)
Originally posted by wildBill83 View PostQuit buying Valuecraft or Duralast branded items and pay for VDP items, they come from OEM vendors and are anything but crap. You will have to wait 2-3 business days to get it but you can't beat their lifetime warranty on vendor direct parts. You can't say AutoZone's stuff is crap if you chose to buy the crap brand that is on the shelf and not the more expensive ones you have to order. What you can say is "I went to AutoZone and chose to buy crap even though I had the option to spend more money on actual OEM replacement parts".
Just remove the air duct, push forcefully with your hand on the rear of the tranny if the tranny clearly shakes it means the rear mount has rips on it or is of bad quality ...... also notice you can't see the rear mount 360 degrees unless you remove a lot of stuff.
I bought one yesterday because mine is 360 torn, I put some epoxy and duct tape but that didn't work and the engine would shake violently when I put Reverse, mine is automatic and I guess because I ignored it, I am having recently other serious problems .... my power steering system is having issues (weird sounds) and my manifold has vacuum leaks. My CV boots are torn too now.
never ignore an engine mount.Last edited by EsperHamid; 08-16-2013, 03:43 AM.
Originally posted by 92accord ex View Posti only went to autozone because i needed right then and there other wise i go straight to the dealership
My point is that you wanted something right now, so you bought it and you bought it knowing it was most likely of lesser quality as you had choices of higher quality more expensive items but chose to forgo them in lieu of convenience. Only parts stores aren't like corner stores, they charge you less for convenience items to make the customer happy right then and there. What you save in cost you lose in time by choosing to use the cheapest most available item off the shelf. In that sense you got what you paid for. It's not AutoZone's fault you chose to be cheap and impatient.
EDIT: Back on topic. Even if you bought a Honda rubber front torque mount it would still be too soft because all of the other mounts are poly.
Have you seen this?
http://www.cb7tuner.com/vbb/showthre...tractor+supplyLast edited by wildBill83; 08-16-2013, 06:26 AM.1993 SE Coupe MRT - 1992 LX Sedan MRT
learn from me. I bought a full set of mounts off ebay and full engine movement for the past 3 years... and want to atleast stiffin my rear with the 5 speed not really concerned about the vibration (I'm already used to it with the current mount) A few J.y cars have good ones im just scared the engine will fall back on me is that true or will the front mount hold it and for the 5 speed swap can I keep the auto bracket or do I need the parts for the 5 speed?
Originally posted by evil_demon_01Do it once, do it right.
Saving a dollar is not worth risking a life.
White -91 LX Sedan - leather converted
Mulberry 91 EX Sedan
The project 92
Originally posted by EsperHamid View Postbut I don't think he did the thread to attack autozone, just saying
Originally posted by 92accord ex View Postlike i said i went to autzone because i needed asap. i dont get what your getting at. i spent 30 bucks on a mount that take about 5 mins to change.1993 SE Coupe MRT - 1992 LX Sedan MRT
Autozone and kregan sell the aame brand motor mounts....anchor brand.
Pull ebrake up hard....have buddy put it in reverse while holding firmly on brake and press on the gas. While you are in the engine bay on the side watch thagt rear mount. If its broken you will see it when the motor lifts.
Hold the gas pedal for amax of 4 seconds and then put it in neutral to cool down the torque converter.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
Originally posted by accordztech View PostAutozone and kregan sell the aame brand motor mounts....anchor brand.
Honda mounts are basically Beck/Arnley that have been re-bagged.
Originally posted by accordztech View PostPull ebrake up hard....have buddy put it in reverse while holding firmly on brake and press on the gas. While you are in the engine bay on the side watch thagt rear mount. If its broken you will see it when the motor lifts.
Hold the gas pedal for amax of 4 seconds and then put it in neutral to cool down the torque converter.1993 SE Coupe MRT - 1992 LX Sedan MRT
