I have a skunk2 manifold I want to slap on the,will be replacing the gasket and was thinking of getting a hondata thermal gasket.This will be going on my daily driver.
are thermal intake manifold gaskets good on a daily driver?
yeah they certainly don't hurt. I've got a Hondata one on mine.
One thing you will run into, you might need longer studs since the gasket is a lot thicker than factory. But if you're careful, and make sure all the nuts are on, it'll work.
I used a little bit of thread lock on the end ones since they wanted to come off every so often. Haven't had any issues since.
Originally posted by Losiracer2 View Postyeah they certainly don't hurt. I've got a Hondata one on mine.
Originally posted by Stephen Fry'It's now very common to hear people say, "I'm rather offended by that", as if that gives them certain rights. It's no more than a whine. It has no meaning, it has no purpose, it has no reason to be respected as a phrase. "I'm offended by that." Well, so fucking what?' —Stephen Fry
Originally posted by steelbluesleepR View PostI believe this is part of what caused my manifold to crack.1993 SE Coupe MRT - 1992 LX Sedan MRT
93 Accord SE Bose Stereo MYTHS & FACTS - F22A* Power Plant Removal(UNDER CONSTRUCTION)
Can any of you guys that are running these on a DD post up your IAT readings and/or the ΔT of IAT and ambient temps. I know they work on a drag car but I would be interested to see how well they work on a DD after some driving time.
Thing that you have to realize is that there are both coolant and exhaust gases that flow through the right side of a stock intake manifold. If you cut off the heat transfer from the head there will be uneven heating. This could cause cracking, it could also cause cylinders 4 & 3 to run hotter.Last edited by GhostAccord; 07-28-2013, 01:31 PM.
Originally posted by 90CB7EURO View PostI been doing some searching and found that you are running a sk2 manifold,how did you go about the egr valve? I've been rrading that some people just hang it somewhere with vaccum line still connected,so they won't get a CEL.I'm using a p13 ecu
Originally posted by 90CB7EURO View PostI been doing some searching and found that you are running a sk2 manifold,how did you go about the egr valve? I've been rrading that some people just hang it somewhere with vaccum line still connected,so they won't get a CEL.I'm using a p13 ecuWhat makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
Originally posted by GhostAccord View PostCan any of you guys that are running these on a DD post up your IAT readings and/or the ΔT of IAT and ambient temps. I know they work on a drag car but I would be interested to see how well they work on a DD after some driving time.
