when i start the car up and push the brake i try to put it in gear and it wont go i have to turn the car off and put the key in the hole and put it in N then start the car. It just started to do it last night..
automatic not lettin me go into gear
Originally posted by AccordNation423 View Postwhen i start the car up and push the brake i try to put it in gear and it wont go i have to turn the car off and put the key in the hole and put it in N then start the car. It just started to do it last night..Last edited by SilverShadow; 06-22-2013, 03:36 PM.
Old wagon - Silver '92 LX Wagon - Steve (Shadow)- STOLEN ON LABOR DAY 2012
New wagon- White '92 LX Wagon on 1/3/13 (Frostbite)
2000 EX Coupe - Joe -
www.AccordWagonClub.com
My Facebook Site - ACCORDOBSESSION
Have you checked your fuses already?
I had the same problem before and it turned to be a fuse. I can also be the brake sensor as stated before, but I would try checking the fuses first since that's the easiest and cheapest place to start looking. Check he ones under the hood and the ones under the dashboard, I can't remember where I found the bad fuse.
The lock solenoid on the side of the shifter under the console may have a short or, blown fuse, or just burned up. It has 3 10mm bolts that hold it in, you can remove it and see if it works when 12v's are applied, if so check the wires leading to it to make sure it completes it's circuit.
This should be a simple cheap fix."Self Renewed"
Have you opened the TCU? There is a common resistor that burns up that controls the shift lock solenoid. If it is doing this eventually the TCU will go into limp mode and you will only have two gears. If this resistor is burnt you might as well replace the adjacent capacitors and matching resistors.1993 SE Coupe MRT - 1992 LX Sedan MRT
93 Accord SE Bose Stereo MYTHS & FACTS - F22A* Power Plant Removal(UNDER CONSTRUCTION)
