I was driving home last night and the engine started randomly jumping. Right before I arrived it got worse to the point where it was basically running on 3 cylinders. So now I'm trying to diagnose what exactly is the problem and was wondering if I could get some insight. When I start it (cold or warm) it idles extremely low now (like 200 rpm) and sounds like it's running on 3 cylinders. When I drive it around it sometimes jumps where suddenly all 4 cylinders are working again and feels smooth, and then starts misfiring again. It seems to be random no matter what RPM. I figured out that it's cylinder #1 because when I unplug the injector it makes no difference, but if I unplug any of the other ones it almost dies.
Here's what I've checked:
-Spark plugs (they all look normal)
-Spark tested all plugs (there is spark)
-Compression tested all cylinders (#1 170 PSI, #2 180 PSI, #3 180 PSI, 4# 180 PSI)
-Tested all injectors with screw driver to my ear (I hear clicking from all of them, even at cylinder #1)
-Checked all ignition cables with a timing light (didn't see any misfiring, and they all synchronized with the engine)
-Checked and eliminated all vacuum leaks
-Cleaned IAC
-Swapped in my F22A1 ECU (been using a P12 ECU. No change in misfiring)
-No check engine lights
Anything else? It doesn't seem like it's the distributor, being that there is spark and the timing light doesn't show anything unusual. I think the diagnosis system is too old to have the technology to detect misfires, since this is a 1991 Accord. This is my daily driver and only vehicle so I'm kind of in an emergency...
Thanks
-Cleaned IAC
Thanks
