front crossmember question....
    Anybody know the name of the bar in the middle of the front crossmember? Just need a name and also if it has been removed will it make like a rattle noise??
    http://www.hondaautomotiveparts.com/...ry5=CROSS+BEAM
    A&P-IA
      It will only make noise if it's stored on a moving or vibrating surface, or an area prone to someone tripping over it. But as long as it's out the way on a level surface it shouldn't, like, make any noise.
        If I remember correctly, it does have provisions for attaching one of the rubber hangers for the exhaust, so without the center support, the exhaust may be making more noise.
          after re-installing mine, I am having the same rattling as the OP but only when I put the gear in "R" reverse
