need help dizzy external/internal coil
    so I am doing an h series swap on my 91 cb but the dizzy the h motor has an external coil and the engine harness doesnt have the wiring for the external coil , does anyone know if I can wire something up thats the only thing preventing me from starting the car
    If you search "coil" in the DIY section then you'll find many applicable results. Usually they're referencing converting to an external coil but the logic is the same.
    Do the reverse of what this DIY instructs and you'll be good. Or, you'll have to buy an internal coil from a JDM F20A/F22B DOHC, H22A or H23A and it will bolt right up and plug right in.
