1500 rpm sputter
    1500 rpm sputter
    I have a sputter between 1500 and 2000 rpm only under a load. I have tried everything I can think of just short of cleaning the egr.
    Any idea what it could be? No cel at all
    visit vgruk
    You may wanna list of things you did so knowledgeable people can contribute to your problem.
    A&P-IA
      Sorry.
      Cleaned iacv
      Replaced fuel filter
      Checked plugs
      Cleaned injectors
      Cleaned air filter
      Cleaned tb
      Checked for TCU/ecu codes (none)
      The only thing I can think of that might cause it would be the hole in my resonator
      it has been doing this since i adjusted my idle speed IAW the idle speed adjust thread
      visit vgruk
        Spark plug wires?
        Distributor cap? Rotor?
        92ex CB7<-SOLD 93ex CB9shiftingshift73C10
          Originally posted by mtnbikaah View Post
          Spark plug wires?
          Wires got about 10k on them.
          The cap and rotor might have 100k plus. I will check it asap
          visit vgruk
            Wouldn't hurt to check them. They are also cheap to replace.
              I will just replace them
              visit vgruk
                Egr ports clogged had the same issue and blocked off the egr and the problem went away.
                My OLD Members Ride Thread
                  Egr ports. I had the same problem. Cleaned them and it went away. It's not all that hard
                  Steve
