Hadsys vs. Denso AC Compressor?
    Originally posted by wildBill83 View Post
    I did the RC-17D to RC-17S swap on my '93 SE a few months back. I can confirm that it is simple and effective and has not failed yet. You only need to swap the back plate.
    I would assume any rebuilt RC-17S out there these days will have an aged clutch, and some companies do not replace or warranty the clutch on rebuilt units. Also the RC-17D internal o-rings are all buna-n and more compatible to R134a refrigerants. By getting a RC-17D and converting you are getting a newer clutch if the rebuilt unit doesn't have a replaced clutch on it already. If you get a remanufactured unit it should come with a new clutch as well as buna-n internal o-rings. Be sure you buy reman units not rebuilt units.
    I have a RC-17S with a frozen clutch too, or else I would mail it to you. All the new clutches I found cost nearly as much as a reman for either RC-17* series compressors.
    I thought about going to denso, but went with the converted reman RC-17D. Also the denso is a 6 piston compressor and the hadsys is a 7 piston compressor.
    http://www.ebay.com/itm/94-HONDA-ACC...d03328&vxp=mtr
    http://www.ebay.com/itm/Honda-Accord...2a5780&vxp=mtr
    ^notice the difference in the back plate furthest from the pulley?
    Are the RC17D clutches the same as RC17S? If so I might be able to get one from a wrecked 5th gen accord. There are tons of them at my Pick N Pull.
    But the shitty thing is, my Pick N Pull is closing for good this Wed, no more in AZ So I have to act quick.
    member's ride thread
    91 Accord SE 176k
      Yes, with the exception being they are a 5 groove pulley clutch. I run a 4 groove belt on it still though.
        I managed to find 3 accords out of at least 100 in a Phx JY that had the Hadsys compressor. Got the best clutch assembly out of the three and put it in....AC works!
        I should've known just from the lower fuel economy I was getting. I was averaging about 23 before and this past tank dropped down to 19-20. Pulley had a lot of friction and wouldn't spin freely because the magnet side of the clutch was starting to fry from getting way too hot.
        On a positive note the AC compressor people I bought the reman compressor from finally sent me a new clutch...right after I purchased this one today for 17 bucks. Oh well, guess I'll have a brand new spare.
        91 Accord SE 176k
          my 93 Ex has a Denso ( made in USA, not in Japan if it matters) ive owned the car since 2004 so if it did come with a Hadsys then I wasnt the one that changed it.
          frostwhite225@gmail.com =VENMO
          http://www.youtube.com/watch?v=NOB38zJu66o
          [COLOR="Magenta"]
            Maybe you've had an engine swap done
            91 Accord SE 176k
              I'm not sure what my original compressor was (probably a Hadsys), but I ran into problems today just as mentioned before.
              I picked up a Denso unit from the yard today as I only need it to last a few months or so (hopefully it does the trick) until I replace it with a new unit. Anywhoot, the two lines would not and could not line up with the Denso compressor. That upset me, but then I figured I'd get two new lines from an auto parts store that lines up and fits correctly with the Denso unit.
              The Lord watches over me!
              "Stop punching down on my people!!!"
              - D. Chappelle
                mine was and still is a Hadsys. I bought a reman'd unit for 170 shipped, you can find them for as low as 140 shipped now.
                the reman unit has been working great. Still blows 38 degrees at the vents 2 years later with R12 in the system.
                91 Accord SE 176k
