hey guys, i am not mechanical at all so i really dont understand what the codes mean. i've gotten these codes on my 92 lx accord, 7, 12, 8 , 4. are these separate things wrong? please excuse my lack of understanding what they are. can someone help me? thanks for reading.
problem figuring out ecu codes
Try this thread out-
http://www.cb7tuner.com/vbb/showthread.php?t=21259
Its under the technical section. There are a lot of other threads in there. Poke around and read up on it, so it will be easier to find next time around.
And yes, to answer your question, all those things are wrong. OR your ECU is going bad. Sometimes a bunch of error codes can be a sign of that.
And as Ralphie said, any of the "sticky" threads at the top of each section, many marked "read here first", will tell you most of the common information you need. That thread he linked to was located in a "read here first" thread located both here AND in the beginner technical forum (so really, you should've read there first TWICE since you joined this site!)
