Yesterday i started my car up as usual and drove about a half mile to the store. Then i stopped and got gas and it started up fine . When i got home and shut the car off , i had to start it again to move into another parking spot. The car was fine. 3 hours later i come out to start it and leave but all i got was a relay click( i guess thats what it was). I assumed my negative wire was loose because i was fumbling with the vss a day ago. Everything was fine.
So far i have smacked the starter, checked the connections, even brought out my dvom to do voltage drops and resistance tests. Everything clears out. I get my battery voltage to the power cable and i have ground. i just had the starter bench tested at autozone and it spun up and passed twice but when i did a direct connection to the battery i wouldnt turn over. My battery is near new. Can someone give me some insight on what else i can check?
