im getting the code tranny lockup valve 1 from my d4 light. anyone know where that is? ive searched but could not find anything on it. also, im getting a code 9 from the check engine light, which i believe is the cylinder sensor or something similar. where would that be located?
Transmission Help
I'm not familiar with auto trannys but I found this info fairly easily. Hope it helps
and
.Last edited by Tishock; 03-26-2013, 06:52 PM.
hmm i swapped the top solenoid from my old car onto this one. well actually swapped the whole tranny from my old car and it worked fine but ever since i put it in this cars its been giving me this code. i never reset the codes when i switched solenoids though. so ill try there and see what happens
