I just replaced my transmission fluid while I was replacing a axle seal. I used Honda MTF and filled it until it came out the fill hole.
This is the first transmission fluid change for this car while in my possession so I'm curious to what fluid was used by the previous owner. I didn't even think about checking the fluid when draining.
If they only used let's say a 10w-30 motor oil for the life of the transmission, would it be better to stay with motor oil or should switching to MTF be better? I didn't have the 3rd gear synchro grinding before I changed the fluid. I was thinking of trying another brand or type of MTF.
What do you guys recommend?
