i was coming around an on ramp kinda fast and the oil light came on and started flashing... i drove home turned off the engine and turned it back on and it never came back on until i hadto hit the breaks hard and then it came on a again and flashed.. did the same thing turned it off and didnt come back on.. but did it again when i went around a tight turn again.. whats up??? anyone..??
oil light is blinking
The light coming on going fast around the corner happens from time to time if the oil is starting to get a bit low and splashes around. The oil splashes to the side and doesn't get sucked up for a second or two causing temporary oil pressure loss so the sensor thinks there's no oil. The stock oil pan doesn't have baffles to prevent the oil from sloshing around.
