I just discovered this while replacing my strut rod bushings today. Crawled under the car just to check things out and saw this green connector with a black and red wire. The red wire was broken already and when I went to unplug it, the black one crumbled as well due to corrosion.
I eventually repaired the connector by soldering on a spare I had on, but I'm just curious as to what it's purpose is for.
I was thinking it might be cruise control related? or maybe clutch related for the clutch switch? but I'm not sure. I'm thinking this may be why, when I went to fix my cruise control after my auto to 5spd swap, it didn't work after wiring in the clutch switch and wiring.
