I was driving and my needle went to C the gauge works, any idea why it would be at C when just a while ago it was at medium?
Repair help with coolant
Then check the voltage at the battery. Also check your battery terminals and body grounds. Awhile ago my alt plug would fall out during hard driving, and when the voltage got low enough, most of my gauges would work intermittently.Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
Originally posted by dj_ender View PostThen check the voltage at the battery. Also check your battery terminals and body grounds. Awhile ago my alt plug would fall out during hard driving, and when the voltage got low enough, most of my gauges would work intermittently.
02 Crv
not sure how the thread when OT but shit keep the forum alive!
any way bros i found out that the mech that put my clutch in (what an ass hole returned my car with out motor oil) did not replace my antifreeze instead he used water thats why it drops under optional temps while on the HWY and normal temp idle. plus its winter. (fucker didn't purge my coolant system either)
