I currently have an oil leak that I can not find..
At first, the oil would drip down my oil pan, onto my drainage bolt and then drip from there. I took a close look and it was my gasket, the gasket was pretty much outside of the gasket and was not good anymore. Ordered some honda bond, and oem oil pan gasket. Took the time to do it this last weekend, I cleaned both the surface of the block and the oil pan before applying honda bond on the areas that are needed. Bolted back up and did a new oil change.
I took the car around the block and and drove it till it was at normal temperature. Came back to check for any oil drip and none. Next day, goes to work, comes home. Boom, oil leaking again! I raised the car to find that after the gasket gets heated it'll expand, thus needing to be tightened more. Did so and leaking went away again, for a day. NO I DID NOT OVER TIGHTEN!
This time the leak isn't from the gasket, it seems to be coming from above the oil pan and then streaming down to my drainage bolt and then from there to the ground.
What other plugs, gaskets, are on the LEFT SIDE (If laying under car, RIGHT SIDE, if looking at engine from up top.) should I look for? Are there any at all on that side of the engine?
