Need a quick and low cost way to stop my car from ticking
    should i get the valves adjusted or use oil stablilizer
    Originally posted by fizzbob7
    adjust the valves.....get a $3 gauge feeler, a 12mm wrench and flathead screwdriver, a 10mm socket/wrench and some pliers......takes a half hour if that
    Exactly!!! Don't forget to consult your tech manual for proper spacing of the intake and exhaust valves. Follow the procedure exactly. You'd be surprised at the number of people that just" wing it" and end up screwing up big time....
    I pooped a hammer!!!
      i winged it.....
      i bet that has something to do with that rocker arm that shot through the oil cap....hmmmm
      I can't tell if you are being serious or joking.....
        i'm only serious when i'm bitching.....so i'm kidding
        lol....gotcha
          i tryed adjusting mines today. there was some play between the cam lobe and the rocker arm how do i noe when its exaclty at tdc.? mines still chatter a lil bit,thought. wats should i do different?
          I Ain't cocky,I'm confident.And when u say im the best it's a compliment.!
            I usually remove the top part of the timing belt cover. On the cam gear, it'll say TOP or UP. When that is lined up with the valve cover bolt down shaft, it's at TDC. Adjust CYL #1 then spin the crank. There's an access hole on the side in the wheel well. Just turn your steering wheel all the way counterclockwise and you can fit a socket and extension in between the wheel and fender well. Turn the crank 1/2 a turn counter clockwise (equivalent to 1/4 turn of the cam gear, just watch the TOP/UP mark on the cam gear) and then adjust CYL #3. Keep doing this until you do all four. Firing order is 1,3,4,2.
              in my opinion if u never done it before then don't do it ur self. get somene who has done it before to do it.
                I have never done it before. But if you get someone to do it for you all the time, you will never learn. How much would a valve adjustment cost? If its alot, then i will consider doing it myself. A Guage feeler, thats what it is called? If i go to an auto parts store and ask for it, they wont look at me weird?
                  I think shops charge roughly $60CAD (about $50US?). It's definetly something you can do on your own. I like to do it once a year. Just make sure you follow the proper steps (like firing order and what valves/tappets belong to which cylinder) and you'll be fine. A Haynes manual is somethng good to read over to make sure you get an idea of what to do. Might be a good time to change the valve cover gasket as well.
                  The feeler gauges are sold at most auto stores. Just make sure you get one that has the proper clearnances you need (I think it was .01 and .007??). Some of them don't go lower than 0.01.
