Code 43 Problem
    Code 43 Problem
    I have a what i think is a code 43. Its my first time doing CEL
    My Problem is: I was crusing on the freeway at 70 when the cel came on. when i got off i noticed the car would idle lower than normal. When i got home i was about to jump the connector when i heard a hissing. i popped the hood and steam rolled out. I had a hole in the coolant hose that runs to the cold idle thing that makes the idle go up and down when cold. I guess my question is: is the code 43 which is fuel, related to the coolant hose? or is it just a coincidence?
    if not what is the possible problem for code 43?
    visit vgruk
    Coincidence.
    Code 43 is Oxy Sensor.
    My 5.7 LS1 Holden Ute
      Originally posted by evil_demon_01 View Post
      Coincidence.
      so does that also explain the low idle?
      visit vgruk
        It can, my CEL causes a high idle. Fix the CEL first, then worry about the low idle.
          alright will do. i just priced out a denso on rockauto. which one do i replace? the one on the manifold? also i have a 5 hour road trip coming up next week. can the oxy sensor wait until then? can i clean it or something like that then replace it when i get back?
          visit vgruk
            There's only one o2. The A1 has an "upstream", in the header, the A4/6 has a "downstream", in the down pipe. Order it using the appropriate trim of your accord. Yes, you CAN wait, but it's gonna effect your mpg...
              so i cant clean it or nothing like that to make it go a little longer? or is it just dickered?
              visit vgruk
                You could try....
                  atm it seems to be an intermitant failure so we will see.
                  I would like to thank you sir for helping out
                  visit vgruk
                    You can generally keep the code from getting thrown by not getting on the gas hard or taking it into higher rpms. But the longer it goes, the easier it it to throw the code, until it finally stays on. Rockauto has pretty fast shipping, just an fyi.
                      im going to see if my grandparents will spot me some for it. im broke as hell and this road trip has me strained enough
                      visit vgruk
                        DENSO Part # 2344095 OE Style
                        Male Connector; w/ 9" Sensor; O.E. Quality Replacement Sensor; Upstream; Engine Code F22A6; Engine Code F22A4
                        this is what rockauto has. i hope this is the right one. because i see male connector and female connector. i know nothing about this stuff
                        visit vgruk
                          It is.
                            this one it is! thanks very much for your help and i will make a diy when i get one
                            visit vgruk
                              Don't forget to use the 5% discount code, it's in the sticky section of beginners off topic.
