Hello, I just bought another CB7 and just trying to verify an issue before I buy the parts. It is a 1990 cb7 with an H22, H23 manual transmission, and also ROH converted with Acura 2.3 parts I believe. When taking off it has a shake or almost wheel hop under acceleration. Also does this when coming out of a corner under acceleration.
Previous owner said it will likely need cv axles. Are they the cause of this issue? Only other thing that hasnt been replaced in front end is he inner/outer tie rods.
If this is the issue, What CV axles will I need to install? Just the regular F22 axles or H series axles?
Thanks in advance
I am new to the H22 stuff
Thanks in advance
