as stated, for some reason, when i step on the brake, the right side tail lights do not light up (left side work fine)...i checked all the blubs, they are fine and i even bought new one, but same problem presist. i check the fues and it's fine...now i'm lost...any suggestions. thanks
93 accord tail light problem
there are sensors in each outer taillight. they sense if the bulbs are out or not via an indication light in the inst cluster under the fuel/temp gauges. if they go bad themselves, there is a chance that they will not be able to output power to the bulb. this may be your problem.
also check to see if the contacts of the bulb holders are clean. oxidation sometimes hinders a good solid contact to the bulb. good luck!
Originally posted by timmy0toolthere are sensors in each outer taillight. they sense if the bulbs are out or not via an indication light in the inst cluster under the fuel/temp gauges. if they go bad themselves, there is a chance that they will not be able to output power to the bulb. this may be your problem.In memory of Jameel Johnson 4.30.05--You will never be forgotten...
MY Car
HydroDunk Mixtapes...check it out
