Ok I know there are already posts about this but I need help. I was attempting to do the timing belt and I got caught up on the crank pulley bolt. I can not get the bolt to break free. I have tried two different impacts and neither have worked. Is there any tricks to break it free? I don't have the special tool so I can't use a breaker bar. I also don't have torches I can use, all I have is a propane torch that is not even close to being hot enough.
Crank Pulley
Map gas and try the impacts again? My first t-belt job years ago, mechanic used a chain wrench over the p/s row, got it off, made afew small chips that I had to clean up w/ a file. Not sure if you could get a good purchase w/ a pry bar on the flywheel via the inspection hole in the block. Last trick I've heard of is removing a spark plug, let's say #1 cyl, when piston is not @ TDC, feed a thick nylon rope down the hole, then bring to/close to TDC. The rope will prevent any further rotation. But then IMO you're taxing the internals and even the valves too possibly
Maybe combine afew of the ideas above like chainwrench + prybar + map gas + huge breaker bar
rent the tool is probably the best option, dont scuff it up too much and return it when the job is done, thats what I didMRT http://www.cb7tuner.com/vbb/showthread.php?t=202004
1992 Accord EX(Canadian)Seattle Silver sedan
shitty dude, I was having trouble like you with the impacts not even budging it so I finally gave in and bought a 18" flex bar and the tool and brought the pulley holder back when I was done. just made up some excuse on how I didn't need it.MRT http://www.cb7tuner.com/vbb/showthread.php?t=202004
Originally posted by Jking72 View Postshitty dude, I was having trouble like you with the impacts not even budging it so I finally gave in and bought a 18" flex bar and the tool and brought the pulley holder back when I was done. just made up some excuse on how I didn't need it.1993 SE Coupe MRT - 1992 LX Sedan MRT
93 Accord SE Bose Stereo MYTHS & FACTS - F22A* Power Plant Removal(UNDER CONSTRUCTION)
Originally posted by cincy90h22 View PostThe EASIEST way to get it off is to put your socket on a breaker bar, position it against the control arm or frame where it will stop when turning clockwise.. get in the car and bump the starter. Works everytime.
Op - drive down to Honda, ask them to undo it then nip it back up.
We do it here for customers all the time.
My 5.7 LS1 Holden Ute
Originally posted by evil_demon_01 View PostYea, no it doesn't. That tightens it.
Carry on.
Where are you finding the 3/4" sockets for the crank? I could only find 1/2" locally..1993 SE Coupe MRT - 1992 LX Sedan MRT
Originally posted by wildBill83 View PostWhere are you finding the 3/4" sockets for the crank? I could only find 1/2" locally..MRT http://www.cb7tuner.com/vbb/showthread.php?t=202004
