Alright, I'm trying to get this issue sorted out with my car. This weekend I was driving it and while I was at an intersection the clutch pedal decided it would not be coming back up. Basically I was stuck at the intersection until I could just force it into gear and go. My girlfriend's house was a couple of miles away and I just tried to get there. It limped but I made it. I tried to bleed the clutch there with her holding pressure on the pedal. I didn't have a reservoir or anything with me so I just had her press the pedal while I opened the bleeder.
It seemed that I was able to get it a little better because the pedal returned and I could shift into gear again with the engine running. I tested it out by going back and then forward and I didn't have trouble shifting so I let it be until morning.
Morning comes and I go to leave and you can feel that I don't have full control over the clutch. I reverse out of my girlfriend's driveway and the flywheel starts to drag and the engine shutters. DI make it to work (barely) a few blocks down from her house and park it. With the engine running I cannot get it to go into gear. The pedal is on the floor and won't come back up unless I pull it up. I got a bleeder reservoir(I have a vacuum pump system at my parent's house 2 hours away) so that has been some help as far as visibility is concerned. Honestly, though, if my girlfriend presses on the clutch and I crack it reseal it and have her let off it just lets out a steady stream. No air bubbles seem to be present. I also cannot improve the pedal action this time.
Does anyone have any idea? I may just go order a master and slave cylinder for my car and throw it on there.
