I've had this for awhile now and couldn't figure it out...but when I go to start the car (H22A coupe) it sounds like the starter is grinding its gears? Its not smooth like it should be with that silky smooth engagement?
Would I need to space it out some? or are Prelude and Accord starters specific? I didn't think they were.
I do have a Fidanza lightweight flywheel, so I don't know if that'll affect this or if the starter just need to be adjusted. If anyone has had this issue in the past, what did you do to fix it?
the closest thread I found that's having similar issues is this one: http://www.cb7tuner.com/vbb/showthre...=starter+noise
Mine is making the same noise, kinda like metal on metal, really scratchy, like when you grind gears almost.
