i just replaced my passengers side front wheel bearing and hub. now, i know youre supposed to do both at the same time, but im short on money. so, my question now is, when im driving anywhere from 10 to 30 mph, my car wobbles like it has a loose wheel or something. its really bad. the steering wheel also floats at 65ish, which i know is my tie rod. could it be my drivers side front wheel bearing? or something else?
Wobbling
Is the wobble erratic or at an even frequency that follows vehicle speed? If the latter, check for a bent wheel or a tire with broken belts. Easiest at home check is to jack up each wheel and rotate it to see if it spins straight or if the tire bulges or tread doesn't run straight. If erratic, with each wheel off the ground, check for obvious play in the bearings and suspension.90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
