Hey guys how it going.. I got some pictures of a worsening oil leak on the bottom of my engine. Check out these pics and let me know what you think it is. It seems like the oil pan gasket is now spraying oil, not seeping it like it was before. Its gotten a lot worse.
Here is the gasket. I think I tightened the bolts too much,
Gasket with oil on it,
I can see oil above the oil pan, this made me think it was the oil sender; however the evidence shows that oil is everywhere, as though it sprayed out from somewhere.
Check out the pics above the pan,
Even the oil sender has oil on it. Made me think it was leaking,
This is the pic which makes me thing that its spraying out of somewhere with a high rate of pressure. This is on the exhaust and it has oil all over it. Even the shifter cable has oil on it. It defies gravity the way its on there, only if it sprayed could it have gotten there.
The oil dripped down the center beam onto the floor.
So there it is. Am I right in saying its the oil pan gasket that is literally spraying oil out? It seems like it. But if that's the case, what steps should i take to fix it? I am open to suggestions.
Thanks,
Mikhail.
Thanks,
Mikhail.
