Ok so I've been fighting with lowish oil pressure for sometime. I've been running 10w40 thorugh the summer and my pressure is fine, a little on the low end at idle but acceptable. But today while driving down the road at 2500 rpms the oil pressure was just a hair below 50psi. Then when I got on it up to 3000 rpms the oil pressure bareley made it over 50psi, but after holding steady at 3000rpms it started to rise. could this be a sign of the pump starting to fail? I tried the same thing at 2500 rpms and it acted the same, it slowly rose to just above 50psi, that was at 2500rpms, it never does that. I never had this happen before.
What could it be. Oil is making it to the valve train, when I remove the oil filler cap after I shut the car off it si spattered with oil.
