Heres my dilema. I noticed a burning oil smell and slight smoke from under the
hood. Checked and found the rear of my engine covered in oil. I cleaned the area, run the engine and noticed oil leaking from between the oil cooler and engine block. I ordered a new seal from a local parts store and installed it. The next day I noticed the burning oil smell again, at first I thought residual oil burning off the exhaust. Nope, put the car in the air and the back of the engine is coated in oil again. so I cleaned the area off, ran the engine but this time I placed a rag on top of the oil filter and cooler in case it was coming from higher up, like the oil pressure switch. What do you know, its leaking from between the cooler again. This time I order one from Honda, remove the filter
and cooler clean and check the mating surfaces, install oem o-ring. 1 day later burn oil smell and slight smoke. Repeat the process, and again leaking from between oil cooler. I'm think about pulling it down again, add some Honda bond to the block, reinstall cooler and call it a day. Wondering if anyone else has experienced this, any good advice would be appreciated.
