1. i have this idle problem, had to bypass my iacv, because the second hole in the throttle body stays open and it idles like its stupid,since i plugged it it hasnt done it but i'm afraid of what this can do to the motor. does any one noe what could be wrong.*it does it as long as the engine's on*
2. i'm getting a code 6 o my ecu,its the coolant temp sensor. now prob. is i changed that and the water pump, thermostat,and most of my hoses. wtf is going on its still shooting 6.* now, i never bled the system, could it be that?
3. what would happen if u use gear oil in the tranny?like say u used 15-90 gear oil. would it cause ur clutch to slip and shit.
4. if the balancer shaft belt is out of time, how can u tell? not visualy i mean will it drive different?
i think thats it for now. thanks.
