ok so im driving along and then all of the sudden i notice that i have nothing in the cluster working. no tach, speedo, temp, fuel, odometer nothing. car is running fine. also windows dont work and neither does the defrost.
the blinkers, lights, hazards all work.
heres what ive done. checked fuses by pulling them all out and looking at them. there all good. kick panel and under hood fuses are all good.
heres what ive noticed, ill put the key in and with the door open it does the ding ding ding over and over thing like its supposed to, i turn the key to the position before the turn to start and i still have the ding ding ding over and over and only the battery light is coming on.
whats supposed to happen when you turn the key to the final position before start with the door open is three long dings then nothing ( i think 3,) well its not supposed to constantly ding ding ding.
im wondering if i have a bad ignition switch or if it could be the key cylinder.
has anybody else had this problem or have an idea i can try. or agrees that its the ignition or cylinder? i appreciate the advice.
