I've been attempting to diagnose a slow leak in my A/C system. When I first bought the car, it worked for about two weeks then stopped, due to the pressure switch flipping. I bought a 134a kit that was designed for converted R12 systems from BiMart, a co-op in Portland. I took the car to an A/C service and had them pressure test it. It holds pressure but there is a small pinhole leak on the suction pipe below the battery. Normally, I'd just get a new hose from Honda, but the part is no longer available through Majestic Honda and my local dealers in Beaverton and Portland, for a 1991 SE. I'm pretty sure they carry it for all the other trims in 1991 and 1992, and even have the 1993 SE. The PN for the 1991 SE suction hose is 80321-SM4-G05 and the 1992 EX one is 80321-SM1-A81. The SE hose is different because of the placement of the ABS reservoir, so I am wondering if a 1992 hose would fit, due to the post refresh CB7's having ABS (for EX models, anyways). I have photos of the route of the hose, and measurements of the hose and at which point it turns. Does anyone have a photo of the hose routing? The part diagrams are the same for both years on Majestic Honda. I think there's another '91 SE at the junkyard but I'd rather buy a new hose than pull one from the junkyard that may have a lot of corrosion on it or be bent.
And the hole that someone drilled through the battery tray, causing the pipe to corrode in the first place.
