pause your vid at 0:20 thats your check engine light that is on.
Failed emission's, helpp!!
this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
my bad thats my mistake . had shit messed up .
you might be able to still pull codes from it though its not on.this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
Originally posted by Charlie View PostHow would i pull codes from it if its not on?
Originally posted by Charlie View PostI tried the egr valve test and i couldnt stall out the car it would bog real low but not stall, i tried two egr vavles and same thing with both
have you checked that red hose i told you to check.this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
Originally posted by Charlie View PostYes i looked at the red hose and it looks fine . Really eh how much carbon build up could be in there?this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
Originally posted by Charlie View Postreally wow, anyways put a new coil on and nothing so im taking it back to the shop later today
if your not going to pull the codes then at least try this.
There are a few reasons the vehicle could be running rich.
One could be an ignition system problem, so make sure the plugs are good, the distributor cap and rotor are new.
If the "tune up" parts are okay suspect either an engine coolant temperature sensor or fuel pressure regulator.
If possible install a fuel gauge to the fuel system and check for excessive fuel pressure. 38psi is max. If fuel pressure is high, or fuel pressure will bleed off when the engine is turned off, replace the fuel pressure regulator.
As far as checking the engine coolant temperature sensor, Monitor the Engine Coolant Temperature (ECT) sensor voltage on the Yellow/Green wire, the voltage should be around 2.5 volts at 70 degrees and 0.5 volts at operating temperature. Verify the voltage does not jump high when the problem occurs. If it does suspect a faulty ECT sensor.
Read more: 91 honda accord: 2.2 running rough no check engine light stalls..rich - smell for fuel in the fuel pressure regulator vacuum line if there is then its bad .
if you dont whont to do this then we can not help you.Last edited by Accord problems; 08-27-2012, 03:58 PM.this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
Originally posted by Charlie View Posti did try and pull the codes and and there was none!this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
Originally posted by Accord problems View PostYOUR CHECK ENGINE LIGHT IS ON . YOU NEED TO PULL THE CODES ! . if the red hose that goes to evap can comes off or is cracked it will act like this mine did. YOUR CHECK ENGINE LIGHT IS ON . YOU NEED TO PULL THE CODES !
you mean the fuel vapor red hose that goes to the charcoal canister ?! sorry don't want to hijack this thread ... but mine is cut, I bought the car like this, I have no oil problem like him though, should I put a new one red hose ...why do they cut it and what are the benefits of putting a new one.
Originally posted by EsperHamid View Post
you mean the fuel vapor red hose that goes to the charcoal canister ?! sorry don't want to hijack this thread ... but mine is cut, I bought the car like this, I have no oil problem like him though, should I put a new one red hose ...why do they cut it and what are the benefits of putting a new one.this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
manually Clean your egr ports. Clogged egr ports can cause a misfire (And a definite rise in Nox) and then results in your co going up.
That shop you took it to knows shit about smog.
You can disconnect the vac line to the egr, if it doesnt miss fire then you know where the issue is.
But I could not see the video.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
