91 SE stalling no CEL's
    Well, problem started once i fixe an open in the a/c system wiring
    with a full load once the car is shifted into reverse or drive and see's 750rpm or less it stalls
    the car has a mp1a prelude trans (bought the car with it)
    i've measured resistance in all timing sensors and have gotten 420-450 ohms
    between all three, coil is in spec and igniter too
    im not getting any CEL's
    but im getting 2 tcu codes after driving on it, again the a/c has not worked on this car for a while so this problem was not present before
    tcu codes are 4, 14
    4 being vss
    14 being linear pressure
    the vss is reading fine, and there's continuity from the orange wire going to the correct pin to the tcu
    last but no least i opened the tcu and she look's new, no burnt capacitors or leaking caps
    the tcu # 28100-px4-832
    the car drives sluggish and the converter doesnt lock up
    any help is apreciated
    Just do what PR CB7 said.
    Have you cleaned out your FITV?
    Mine was doing this as well and i cleaned out the carbon build up and it was perfect.
      There is no fitv on this car
      Any other imputs
        so its been deleted?
          Is the trany wired right?
            fitv is deleted
            trans is wired right
