hey, i got my ignitor and i need to know how to remove the rotor. i took off the cap (only 3-8mm bolts) but i cant get the rotor off so i can get to the ignitoir. i looked at the online shop manual...couldnt find anything, thanks
cap and rotor removal for distributor?
Actually the rotor on F22 engines have a flat spot on one side to make it idiot proof in not installing it wrong, you can't go wrong.
On our 88 Integra 1.6L DOHC (d16a1) engine, the rotor has a small set screw that you have to remove before taking the rotor off. We don't have that on our F22 engines...I'm like 98% sure...man, I'm forgetting crap. I've done this a few times before too on our Accords, it's just been a bit.
I just did mine not too long ago. If the rotor gives you a hastle, hit it with some WD40 and use a flathead screwdriver to pry it off.ProjectParty.net
Putting an end to the question, "What's going on tonight?"
"This generation has this universal sense of failure" - Kurt D. Cobain
CLUB 1320
My FOR SALE thread...buy my ish
w00t, used a bit of leverage from a flat head, then removed by hand.
for the ignitor, once you take the rotor and covering under that off. there's two screws that are facing you, take those out and you will see the ignitor...
two screws under the ignitor should take out an assembly attached to the ignitor.
pull whole thing out, swap old with new and reverse assembly, ta da!
the difference is night and day, my car sounds so much better, no tach jumping after 3k, hopefully the mileage will improve since it was misfiring and hesitating a bit.
thanks for your help guys!
