No weld O2 AEM AIR TO FUEL SENSOR, do you trust it?
Originally posted by danf20bcb7 View Postonly if you use some silicone to help seal it up. yes
I've always had a bung welded on for my widebands but I don't see any reason this wouldn't work as long as the drill bit you use is the correct size.
Originally posted by Sordz View PostDon't do this, temps will be far to high for any silicone I know of.
Originally posted by danf20bcb7 View Postive used high temp red on my turbo gaskets and never had any issues. and being that ive used this aem weldless before on customers cars and the ones that i didnt use silicone on leaked.
Depending how far down stream you mount the wideband that red silicone might hold up. Since the aem wideband comes with a bung it would be best to just get it welded IMO.
Originally posted by deevergote View PostThis.
I paid $30 to a drunk Russian to weld my secondary o2 bung onto my car... and I think I overpaid!
Sure, that product will work just fine... but I think AEM is taking advantage of lazy people.
seems legit though, if you want to go this route
Originally posted by Sordz View PostLiquid copper would be better for your turbo gasket, I really doubt silicone will hold up long at 1500+ degrees.
