91 cb7 car wont start.
if you spray starter fluid in intake it starts then dies. therfore the ignition can be ruled out its a fuel issue. i tested the main relay and it past i test the harness it past i even tried the resitor box and it passed spec were from all data. i starting to think its the ecu . but before i go get one is there somthing i might be over looking?
is there a way i can check the plugs that go to the injectors ?
any specific grounds i should check?![Confused](http://www.cb7tuner.com/confused.gif)
