Nox rate failed smog
    Went to to do a smog test failed smog on the NO(PPM)
    I passed everything but the NO (ppm)
    The numbers are
    Max/ave/mea
    15 MPH 559/298/789 Fail
    25 MPH 516/234/508
    I only passed on evertthing tho with fyling colors
    1 week prior I did a full tune up and seafoamed the car. I run 89 in the tank maybe I'll start running 91. Change 02 sensor
    What could cause such a high no reading
    NEW CB
    old Darkcloud : 1990 Accord EX MRT
    new
    DARKCLOUD : 90 ACCORD EX MRT
    Clean your egr ports. The best way is removing the intake man.
    Take a look at my MRT!! Thanks
    http://www.cb7tuner.com/vbb/showthread.php?t=186609
      I'll be doing that anything else I can do
      NEW CB
      new
        Yeah cleaning the ports should help. If I remember correctly; you can actually drill the intake runners close to the head, clean out the build up and then plug up the holes with caps. (which Honda sells)
          i had the same issues with my accord, passed everything but the NO part, i cleaned the egr ports, changed my sparkplugs and made sure that timing was set correctly using a light gun. my car was of by a couple degrees , after that it passed with flying colors all across.
          CALI LIFE STYLE
          http://www.cb7tuner.com/vbb/showthread.php?t=145883
            91 octane and retard timing to 13 degrees. (you are allowed up to 3 unless specified)
            california fucking sucks. 500ppm nox for an early 90's car? they must be high.
              Yea retard the timing and it should drop down.
              COUPE K24
                Since you seafoamed the car pull the sparks out,clean them off and regap them.if you havent replace them since buying the car,replace.clean out your egr and retard the timing a bit.
                  Seafoamed before tune up.
                  Could a bad cat cause high nox
                  NEW CB
                  new
                    Our limit on the 25/25 for nox is ontario on a cb is 467, and most cb's that come in blow around 200range the ones that come in an pass that is lol, heck my cb blew 91ppm out of 467ppm, so 500 is pretty leniant for cali, yes I know the temp is different in cali then ontario but still.
                    1993 CB6 Coupe Seattle Silver YR-94M
                    Originally posted by Acclude
                    4gens are win. It's in the bible somewhere.
                    yeah its verse 10.6:1
                    Members Ride Thread
                    1993 Accord Coupe- Summer ride
                    http://www.cb7tuner.com/vbb/showthread.php?t=130064
                    1995 Civic Coupe - Winter/DD
                    http://www.cb7tuner.com/vbb/showthre...53#post2744953
                      wowzers thats amaxing. ive seen a lot of 5th gens and preludes fail for nox.
                        It can but if your passing the high speed test i think the cat is working. high nox means you are running really lean.Does your cb have a slight stumble when its idling?
                          i 5 gas tested my car at school and my nox failed at idle due to a vacuum leak but it got better as i increased the speed
                          10th Anniversary Accord.
                          05 Audi A4 Ultra Sport 6MT.
                            yea most 4th gens and 5th gens do fail had a few ludes fail but that's the owners fault for lack of maintenance, most vtec engines pass compare to non vtec
                            Members Ride Thread
                              unfortunately egr port cleaning isn't a scheduled maintainence.
