Today my friend mentioned that my clutch engages very high up, almost near the very top. I don't know if this is normal because I have a new exedy stage 1 clutch, a 8lb flywheel and the f20a engine. I remember bleeding the clutch twice after the install and my cylinders arent leaking. What can be the cause of this, should I bleed it again?
Problem with clutch.
its a 12mm lock nut on it.....when your under the dash, if ur rotate it counter clock wise while ur upside down, it will lower the engagement point....so spin it to ur left while ur upside down, and u should have about an inch of play in the pedal....good luck.Finally Up and Running. Numbers to Follow. Check my MR
Originally posted by mayberry4thgenits a 12mm lock nut on it.....when your under the dash, if ur rotate it counter clock wise while ur upside down, it will lower the engagement point....so spin it to ur left while ur upside down, and u should have about an inch of play in the pedal....good luck.You have been defeated by a car with child locks, how embarassing...
"I noticed my f22 felt "healthier" until it blew up." <Myk>
Originally posted by WiKKeDV16in lamen terms.. look for a small diamter shiny rod that goes into the engine bay from under the clutch pedal.. it should have a 12mm nut on it.. i forgot which side.. either right behind the clutch pedal or right infront of the firewall..You have been defeated by a car with child locks, how embarassing...
Originally posted by mayberry4thgenits a 12mm lock nut on it.....when your under the dash, if ur rotate it counter clock wise while ur upside down, it will lower the engagement point....so spin it to ur left while ur upside down, and u should have about an inch of play in the pedal....good luck.Last edited by Alex EX; 03-20-2005, 03:23 AM.You have been defeated by a car with child locks, how embarassing...
